Group: DynoMotion Message: 4190 From: dotma99 Date: 3/7/2012
Subject: Simultaneous commands
Hi Tom
I have just bought a kflop and kanalog and am very impressed so far.
A question. I have built a machine for a specialised drilling process and I want to be able to move my Z axis down, while simultaneously starting a program which starts a sequence of firing two solenoids. Control needs to returned to the G code program on completion of the solenoid program, not the Z move.
I have looked at the NotifyTapMach3 v2.c example which has some clues, but I am not knowledgeable enough to extrapolate that to my application.
Could you give me some help with this?
thanks in advance
Edward
Group: DynoMotion Message: 4192 From: Tom Kerekes Date: 3/7/2012
Subject: Re: Simultaneous commands
Hi Edward,
I assume you wish to use Mach3?
I think you may need to use a Virtual IO bit to force Mach3 to wait until your sequence is complete.
It sounds like an approach as follows may work:
Configure Mach3 Ports&Pins Input #1 as Port1 Bit48
Define a VB Mcode M180
      NotifyPlugins(10080)   'this will tell KFLOP to clear a virtual bit #48 and start Solenoid Sequence
Define a VB MCode M181
      while(IsActive(1))
          Sleep(10)
      end while
KFLOP Notify program:
if (msg==10080)
    SetBit(48);  // signal we are busy
    SetBit(XXX);  // solenoid on
    Delay_sec(5);
    ClearBit(XXX); // solenoid off
    ClearBit(48); // signal we are done
In GCode
M180
G1Z1F10
M181
Let me know how much of this makes sense
Sent: Wednesday, March 7, 2012 5:06 AM
Subject: [DynoMotion] Simultaneous commands
Hi Tom
thanks in advance
Edward
Group: DynoMotion Message: 4193 From: Edward Forwood Date: 3/7/2012
Hi Tom
Thanks, but I am using KmotionCNC (apologies, I should have said so).  I am not quite clear how to implement in Kmotioncnc.  Presumably it’s a bit easier?  The machine is designed to drill at 4 holes plus per second so timing is important!  Just to confirm the solenoid sequence needs to start at the same time as the z axis starts to move.
Best regards
Edward
Sent: 07 March 2012 16:29
Subject: Re: [DynoMotion] Simultaneous commands
Hi Edward,
      while(IsActive(1))
          Sleep(10)
      end while
if (msg==10080)
    Delay_sec(5);
In GCode
M180
G1Z1F10
M181
Hi Tom
thanks in advance
Edward
Group: DynoMotion Message: 4195 From: Tom Kerekes Date: 3/7/2012
Hi Edward,
In this case it would probably be better to have the GCode Set a Virtual IO bit that an already running C program could detect to start the solenoid sequence.  In KMotionCNC there is a way to insert buffered IO commands into the motion buffer that will happen in exact sync with the motion.  So for example in GCode:
(BUF,SetBitBuf48);
G1 Z-1 F10
(BUF,ClearBitBuf48)
Then in KFLOP C code
for(;;) // loop forever
    while (!ReadBit(48)) ;  // wait for signal
    SetBit(XX);  // solenoid on
    Delay_sec(0.1);
    ClearBit(XX); //solenoid off
    while (!ReadBit(48));  // wait for signal to reset
The C code loop might be added to the end of your Init.c program
Sent: Wednesday, March 7, 2012 9:12 AM
Subject: RE: [DynoMotion] Simultaneous commands
Hi Tom
Best regards
Edward
Hi Edward,
      while(IsActive(1))
          Sleep(10)
      end while
if (msg==10080)
    Delay_sec(5);
In GCode
M180
G1Z1F10
M181
Hi Tom
thanks in advance
Edward
Group: DynoMotion Message: 4205 From: dotma99 Date: 3/10/2012
Hi Tom
Thanks for that response. Another simple question. Is there a way of triggering a command like "ClearBit154" as soon as Feed Hold or Stop is pressed in KmotionCNC?
best
Edward
> Hi Edward,
> (BUF,SetBitBuf48);
> G1 Z-1 F10
> (BUF,ClearBitBuf48)
>     Delay_sec(0.1);
> From: Edward Forwood <edward@...>
> Hi Tom
> Best regards
> Edward
> From:DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes
> Hi Edward,
>       while(IsActive(1))
>           Sleep(10)
>       end while
> if (msg==10080)
>     Delay_sec(5);
> In GCode
> M180
> G1Z1F10
> M181
> From:dotma99 <edward@...>
> Hi Tom
> thanks in advance
> Edward
Group: DynoMotion Message: 4206 From: TK Date: 3/10/2012
Not directly. You would need to write a c program to monitor the Stop Status or Axis Enables.
On Mar 10, 2012, at 7:47 AM, "dotma99" <edward@...> wrote:
Hi Tom
best
Edward
> Hi Edward,
> (BUF,SetBitBuf48);
> G1 Z-1 F10
> (BUF,ClearBitBuf48)
>     Delay_sec(0.1);
> Hi Tom
> Best regards
> Edward
> Hi Edward,
>       while(IsActive(1))
>           Sleep(10)
>       end while
> if (msg==10080)
>     Delay_sec(5);
> In GCode
> M180
> G1Z1F10
> M181
> Hi Tom
> thanks in advance
> Edward
